It is currently Mon 20. May 2024, 23:55
PostPosted: Tue 12. Oct 2010, 19:52
Here's a model on politics that you can look at via the attached screenshots or with the demo version of the MODELER. It shows how you can visualize arguments on any topic - in this case some fatal dynamics of the current developments in the US
Please place your models !
File comment: The model itself
USAdemocrats.cons [39.73 KiB]
Downloaded 906 times
File comment: Example of insight matrix: job losses are caused by conservative thinking
File comment: Qualitative model with rough weighting (weak, middle or strong)
File comment: Brainstorming prior the modeling
File comment: Description of the model's scope
PostPosted: Tue 12. Oct 2010, 23:30
Kai N.: Very interesting, TVM.
Only one question. Why do you mention that the main reason of loos of jobs is the conservative thinking. It is not clear to me from the insight matrix. The way I read it, but I am only starting to use your excellent product, is the world´s economy. Conservative thinking has an impact of only 1.7. Hope you can comment on this.
Greetings from Mexico.
Arturo
PostPosted: Wed 13. Oct 2010, 18:46
Well, I hope I didn't label it the main reason. I think it is already enlightening that it increases job losses. Of course, the world economy and other factors have a greater impact - though some of them in a greater model would depend on change or the lack of change in the US, too.
PostPosted: Sun 2. Jan 2011, 21:06
Just a hint: I tried to run a simulation with consideo modeler (demo) 7.0, but it failed. I have got the system message "Simulationsfehler: Ein fehlerhaftes Modell kann nicht simuliert werden".
Regards,
Jürgen
PostPosted: Sun 2. Jan 2011, 22:29
It is a mere qualitative model that cannot be simulated without added formula (and the specification of starts and ends within loops). Via the menu help you can choose 'show issues' to see what is missing to run a simulation.
To get the insight-matrix as the result within qualitative models you have to choose it via context menu from the factors...
